Control Center
This screen allows you to set the appearance of the
internal Control Center window. The internal Control Center can be
either windowed or background. You can also select if you want the
tab control to be visible or not and if visible, how the tabs will
appear. The two settings that may require an explanation are below:
Click on Mouse Up
This parameter controls how the Control Center
responds when clicking on Control Center buttons with the mouse. If
this parameter is checked, then the action associated with the Control
Center object will not be added to the execution queue until the mouse
actually clicks up. When the mouse clicks up, you MUST be on the
Control Center object whose action you want to perform. If this
parameter is unchecked, then the action associated with a Control Center
object is sent to the execution queue immediately down clicking the mouse.
Auto Clear Changes
The Control Center has a table called ccbuttonstemp
that is a mirror of the ccbuttons table (where the Control Center object
details are stored when editing the Control Center from the PowerHome
Explorer). When a Control Center screen is rendered, the values are
read from the ccbuttonstemp table rather than the ccbuttons table.
Since details of Control Center objects can be dynamically updated via
PowerHome functions, the updates are done to the ccbuttonstemp table and
not the ccbuttons table. This parameter controls how often the
dynamic changes made to the ccbuttonstemp table are discarded (the
ccbuttons table is copied to the ccbuttonstemp table).
