Plugin: FireTV Control via ADB
Launch Data (ActiveX
Classname):
PH_FireTV.phfiretv
Initialization Data:
A full path and filename to the plugin INI
file. A base configuration INI file can be found in the plugins directory
at c:\powerhome\plugins\firetv.ini. Details on how to configure the INI are provided
below.
INI File Configuration:
The base configuration INI file
contents will appear like this:
[settings]
ip=192.168.0.128
adbpath=C:\android_sdk\adt-bundle-windows-x86-20130522\sdk\platform-tools
kill=yes
Set the IP parameter to the IP
of your FireTV device. It is best if you can configure a static DHCP address for
your FireTV so that the IP does not change. Set the "adbpath" parameter to the
full path where the ADB.EXE file can be found. The "kill" parameter should be
set to either "yes" or "no". If set to "yes", then the plugin will attempt
to kill the ADB server whenever the plugin is enabled or disabled.
Killing the ADB server helps with problems where the ADB server is
sometimes hung.
Controller Commands
supported:
The following controller
commands are supported by this plugin and can be activated by using the
ph_picmd( ) function. Instead of using the "command" parameter and supplying a
command number, this plugin uses the "parm3" parameter to differentiate between
the different commands using the strings below:
| Parm3 Command |
| killserver |
Sets the "kill" flag (same as the INI file
parameter) to either "yes" or "no". The value you wish to set is int the
Parm1 parameter. Use 0 for "no" and any other value for "yes". |
| up |
Sends an up arrow command |
| down |
Sends a down arrow command |
| left |
Sends a left arrow command |
| right |
Sends a right arrow command |
| enter |
Sends an Enter or Select command |
| select |
Same as the "enter" command above |
| back |
Sends a back command |
| home |
Sends a home command |
| menu |
Sends a menu command |
| play |
Sends a play command |
| pause |
Sends a pause command |
| prev |
Sends a previous command |
| next |
Sends a next command |
| power |
Sends a Power command |
| volup |
Sends a Volume Up command |
| voldn |
Sends a Volume Down command |
| delete |
Sends a delete command |
| tab |
Sends a tab command |
| key |
Sends a keystroke(s). The key to send will
be in the Parm4 parameter. If multiple characters appear in the string
passed in Parm4 then the characters will be sent sequentially one at a
time. |
Generic Plugin triggers
fired:
None
