Plugin: MQTT
Launch Data (ActiveX Classname):   PH_Mqttpi.phmqttpi
Initialization Data: A full path and filename to the plugin INI file. A base configuration INI file can be found in the plugins directory at c:\powerhome\plugins\phmqttpi.ini. Details on how to configure the INI are provided below.
This plugin provides support for MQTT (Message Queue Telemetry Transport) protocol. This technology is in use by a large number of IOT (Internet Of Things) devices and even be implemented in your own DIY projects such as those based upon Arduino or ESP8266/ESP32 devices. Before using this plugin, you must first have setup and configured an MQTT broker. To learn more about MQTT, please visit the homesite at http://mqtt.org
The PowerHome MQTT plugin (as well as the PowerHome MQTT controller) make use of the open source M2Mqtt C# code written by Paolo Patierno to handle the low level MQTT transactions and protocol. You can find the M2Mqtt sourcecode repository here: https://github.com/eclipse/paho.mqtt.m2mqtt and you can find the M2Mqtt homepage here: https://m2mqtt.wordpress.com/
In order to use the MQTT protocol in your environment, you must first install and setup an appropriate MQTT Broker (Server) which acts as a central hub for all MQTT incoming and outgoing messages. There are a number of free brokers available for a variety of platforms. One of the most popular ones is Mosquitto and can be installed on the PowerHome machine itself. You can learn more about this broker at its homesite at https://mosquitto.org. As an alternative to installing and running your own MQTT broker, you can make use of any number of brokers that are available on the web.
PowerHome supports MQTT via this plugin and the PowerHome MQTT controller. You can use one or the other or both of them at the same time. A common use would be to use the PH MQTT controller for device status/update in the Analog IO screen and the MQTT Plugin for all other tasks.
INI File Configuration:
The base configuration INI file contents will appear like this:
[setup]
host=192.168.0.125
port=1883
secure=0
cacert=
clientcert=
sslprotocol=0
clientid=PH MQTT Plugin
userid=
password=
willflag=
willtopic=
willqos=
willretain=
willmessage=
cleansession=
keepaliveperiod=
publishprefix=
subscribeprefix=
subscribecount=4
options=0
[subscribe_1]
topicfilter=#
qos=0
actiontype=1
action=
[subscribe_2]
topicfilter=ph/lights/+
qos=0
actiontype=9
action=ph_msgbox("Variables",ph_returnallvars(6),90)
[subscribe_3]
topicfilter=ph/test/+/light
qos=0
actiontype=1
action=
[subscribe_4]
topicfilter=+/+/#
qos=0
actiontype=1
action=
A number of the parameters in the [Setup] section of the INI file are the same as for the MQTT Controller. The Host and Port parameters should be set to the IP and Port of your MQTT broker. If your broker is configured for secure communications (SSL/TLS), then set the Secure parameter to 1. Otherwise set to 0. If you set the Secure parameter to 1, then you must supply the CA Certificate and Client Certificate in the CACert and ClientCert parameters. If the Secure parameter is 0 (for no secure communications), then set the SSLProtocol parameter to 0. If the Secure parameter is 1, then set the SSLProtocol parameter to the number representing the SSL/TLS protocol in use by the broker (0 - None, 1 - SSL v3, 2 - TLS v1.0, 3 - TLS v1.1, 4 - TLS v1.2)
Set the ClientID to a unique identifier (unique within the broker) to identify your the plugin instance of the MQTT client. If you are also running the MQTT Controller (or multiple instances of the MQTT Plugin, you must make the ClientID different within each instance if they are connecting to the same broker). If your broker requires a userid/password, then set those values in the UserID and Password parameters.
The MQTT protocol allows for a "Will" message for a client. More information can be found on the MQTT site. Basically it is a topic/message that is the last data that will be sent when the client disconnects. If you want a "Will" message, set the WillFlag parameter to 1. In not, then set it to 0. If you set the WillFlag to 1, then you need to specifiy values for the WillTopic, WillQOS, WillRetain, WillMessage parameters.
Set the CleanSession as appropriate to either 1 (CleanSession = true) or 0 (CleanSession = false). Basically, setting the CleanSession flag to false means that the broker will save the client session on disconnection (subscribed topics, messages for these topics delivered on reconnection). If you set the CleanSession flag to true (usually the default), the broker will NOT retain data to be sent to the client when it reconnects.
Set the KeepAlivePeriod to an appropriate value in seconds. Setting this parameter to 0 disables the Keep Alive mechanism. The default value is 60 (seconds). This parameter is the maximum amount of time for no communication (either way) between the broker and the client to occur before the client will be disconnected.
Set the PublishPrefix and SubscribePrefix parameters to appropriate values if you always want to have a set "prefix" for your topics. If you don't want prefixes, you can leave these parameters blank.
The Options parameter is not a part of MQTT and instead controls how the plugin works. This parameter is a flags parameter where you add the desired values together to a total. A value of 1 indicates that the plugin will fire "Status" triggers when they occur. Status triggers are fired when the MQTT connection is closed, a message is published, a topic is subscribed, or a topic is unsubscribed. This value would typically be used during initial debugging to determine if these events are occurring properly. A value of 2 tells the plugin to fire "Exception" triggers. An exception trigger occurs whenever an exception occurs within the plugin. Normally there shouldnt be exceptions but this option may be handy for debugging purposes or to catch when an exception occurs in normal use. In normal use scenarios, you would usually set the Options parameter to either 0 or 2. In a debug scenario, a value of 3 (1 + 2) would be the preferred setting.
The last parameter to be concerned with is the SubscribeCount. Set this parameter to the number of topics you wish the plugin to subscribe to and to be configured in the following [subscribe_?] sections. If you wish to subscribe to 4 topics, then you'll have [subscribe_1], [subscribe_2], [subscribe_3], and [subscribe_4] sections.
Each [subscribe_?] section has 4 parameters with the TopicFilter and QOS parameters being self explanatory if you're familiar with the basics of the MQTT protocol. The ActionType and Action parameters instruct the plugin what to do when a message is received on one of the subscribed topics. The ActionType parameter is a flags parameter where you the values together to get the desired total value. A value of 2 indicates that the Action is a Device Control string. A value of 4 indicates that the Action is a Macro ID. A value of 6 indicates that the Action is a Formula ID. A value of 8 indicates that the Action is a raw formula. You will ONLY use 1 value from the 2, 4, 6, 8 action option values. To the action value you've chosen, you may add a 1 to have the plugin also fire a trigger within PowerHome. If you ONLY want a trigger to be fired when a message is received on a topic, set the ActionType to 1. If you wanted to fire a trigger AND execute a Device Control string, set the ActionType to 3, etc. The Action parameter will be set to the value that corresponds with your chosen ActionType (blank if you didnt choose an action type option (2, 4, 6, or 8).
Controller Commands supported:
 Command Parm1   Parm2  Parm3  Parm4  Description
0   0        Return details on all Subscribed topics
0   1 thru SubscribeCount        Return details on Subscribed topic number specified in Parm1
1   0        Return all configuration INI parameters in the [Setup] section (except for Password)
1   1        Return the [Setup]Host parameter
1   2        Return the [Setup]Port parameter
1   3        Return the [Setup]Secure parameter
1   4        Return the [Setup]CACert parameter
1   5        Return the [Setup]ClientCert parameter
1   6        Return the [Setup]SSLProtocol parameter
1   7        Return the [Setup]ClientID parameter
1   8        Return the [Setup]UserID parameter
1   9        Return the [Setup]WillFlag parameter
1   10        Return the [Setup]WillTopic parameter
1   11        Return the [Setup]WillQOS parameter
1   12        Return the [Setup]WillRetain parameter
1   13        Return the [Setup]WillMessage parameter
1   14        Return the [Setup]CleanSession parameter
1   15        Return the [Setup]KeepAlivePeriod parameter
1   16        Return the [Setup]PublishPrefix parameter
1   17        Return the [Setup]SubscribePrefix parameter
1   18        Return the [Setup]SubscribeCount parameter
1   19        Return the [Setup]Options parameter
2   1 thru SubscribeCount  0      Return the Subscribed Topic for the [Subscribe_?] specified in Parm1
2   1 thru SubscribeCount  1      Return the Subscribed QOS for the [Subscribe_?] specified in Parm1
2   1 thru SubscribeCount  2      Return the Action Type for the [Subscribe_?] specified in Parm1
2   1 thru SubscribeCount  3      Return the Action for the [Subscribe_?] specified in Parm1
3   0        Unsubscribe from all topics and then Subscribe to all topics
3   1        Unsubscribe from all topics
3   2        Subscribe to all topics
3   3  1 thru SubscribeCount      Unsubscribe from topic specified in Parm2
3   4  1 thru SubscribeCount      Subscribe to topic specified in Parm2
4   0, 1, or 2 (QOS)  ActionType value  Topic filter  Action string  Adds an "on the fly" topic subscription (not described in the INI file) to the current list of subscribed topics. See the INI configuration info above for the values to use for the Parm? fields
5   1 thru SubscribeCount  ActionType value  Topic filter  Action string  Update/Change the Subscribe parameters for the Subscribe topic number specified by Parm1. The QOS will be 0
6   1 thru SubscribeCount  ActionType value  Topic filter  Action string  Update/Change the Subscribe parameters for the Subscribe topic number specified by Parm1. The QOS will be 1
7   1 thru SubscribeCount  ActionType value  Topic filter  Action string  Update/Change the Subscribe parameters for the Subscribe topic number specified by Parm1. The QOS will be 2
8       Topic filter    Searches the subscribed topic filters for a match with the topic filter specified in Parm3 and returns the index number if found. If not found, returns 0
10   0        Returns 1 if the MQTT client is connected, 0 otherwise
10   1        Returns 1 if CleanSession is true, 0 if false
10   2        Returns the Client ID
10   3    "get"    Returns 3 if the MQTT client version in use is 3.1. Returns 4 if the MQTT client version in use is 3.1.1
10   3  3 or 4  "set"    Sets the MQTT client version to 3.1 if Parm2 = 3 and 3.1.1 if Parm2 = 4
10   4        Return the MQTT client Attempts On Retry value
10   5        Return the MQTT client Delay On Retry value
10   6        Return the MQTT client InFlight Queue size
10   7        Return the MQTT client Port
10   8        Return the MQTT SSL Port
10   9        Return the MQTT client Timeout on Connection value
10   10        Return the MQTT client Timeout on Receiving value
10   11        Return the MQTT client Will Flag value
10   12        Return the MQTT client Will Topic
10   13        Return the MQTT client Will QOS
10   14        Return the MQTT client Will Message
100   0, 1, or 2 (QOS)  0 or 1 (Retain flag)  Publish Topic  Publish Message  Publish a message using the values in the supplied parameters
Generic Plugin triggers fired:
 Command  Option  Description
1 thru SubscribeCount  1   This trigger is fired if the ActionType for the Topic filter that is matched to an incoming message is set to fire a trigger (Action Type values 1,3,5,7,9). The Command parameter will be set to the [subscribe_?] index number that matches the incoming message. An incoming message MAY match multiple subscribed topics and a trigger (with the appropriate Command value) will be fired for each match.
255  1   Fired when the MQTT client connection is closed
255  2   Fired whenever the plugin MQTT client successfully Publishes a message to a Topic
255  3   Fired whenever the MQTT client successfully Subscribes to a Topic
255  4   Fired whenever the MQTT client successfully UnSubscribes from a Topic
256  1   Fired when an exception occurs when trying to determine the plugin local IP
256  2   Fired when an Invalid Topic Filter exception occurs
256  3   Fired when an exception occurs with creating the MQTT client object
256  4   Fired when an exception occurs with the MQTT client connecting to the broker
256  5   Fired when an exception occurs with the MQTT client disconnecting from the broker
256  6   Fired when an exception occurs with destroying the MQTT client object
256  7   Fired when an exception occurs when Subscribing to an MQTT Topic
256  8   Fired when an exception occurs when UnSubscribing to an MQTT Topic
