Date / Time Functions
PowerHome supports a number of functions that return date, time, or datetime datatypes as well as functions that accept these data types as parameters. This has sometimes been a source of confusion as to exactly what these datatypes are. Details concerning these unique types are below.
All 3 datatypes (date, time, datetime) support a "literal" representation. This is essentially a hard-coded representation of the value (similar to a string but without quotes). Its not often used as most of the time you'll pass date, time, and datetime parameters within a string to a conversion function before using as a parameter in a function that requires a date, time, or datetime value.
Functions that return these datatypes, if not used as an input to another function that requires these datatypes, will have the value converted to a string for storage within a global, local, or temp variable. PowerHome has no concept of date, time, or datetime variables and stores ALL values as a string datatype.
Literal values for these three datatypes must appear in the same format as specified in the Windows Region and Language Localization control panel. In the US, this is typically yyyy-mm-dd for date values and hh:mm:ss for time values. In a different country or region, its likely to be something different.
Date
The date datatype contains only date values. You can use a date literal such as 2015-01-15 (see literal format above) or a function that returns a date value such as date() or relativedate()
Time
The time datatype contains only time values. You can use a time literal such as 22:15:45 (see literal format above) or a function that returns a time value such as time() or relativetime()
Datetime
The datetime datatype contains both a date and a time value. A datetime literal is made by combining a date literal with a time literal and separating the two with a space (see literal formats above). A valid datetime literal would look like this:
2014-07-15 17:40:00
You can also get a datetime value by using a function that returns a datetime value such as datetime() or ph_relativedatetime()
Examples of valid date, time, and datetime functions can be seen below:
• date("1-23-15") --> evaluates to: 01/13/2015
• date("Jan 23 2015") --> evaluates to: 01/13/2015
• datetime(today(),08:15:00:0000) --> evaluates to: 01/11/2015 08:15:00
• datetime(2010-12-15, 10:49:00) --> evaluates to: 12/15/2010 10:49:00
• dayname(2010-12-15) --> evaluates to: Wednesday
• month(2014-12-15) --> evaluates to: 12
• month(date("02/14/2015")) --> evaluates to: 2
• ph_relativedatetime(today(), 10) --> evaluates to: 01/15/2015 14:37:08
