asc PowerHome formula function
Converts the first character of a string to its Unicode integer value.
asc ( string )
string
The string for which you want the Unicode value of the first character
Integer. Returns the Unicode value of the first character in string.
Use Asc to test the case of a character or manipulate text and letters.
To find out the case of a character, you can check whether its Unicode value is within the appropriate range.
