asca PowerHome formula function
Converts the first character of a string to its ASCII integer value.
asca ( string )
string
The string for which you want the ASCII value of the first character
Integer. Returns the ASCII value of the first character in string.
Use AscA to test the case of a character or manipulate text and letters.
To find out the case of a character, you can check whether its ASCII value is within the appropriate range.
