d2b PowerHome formula function
Converts decimal number into binary
string
d2b( number, length )
| number |
Unsigned Long. The decimal number to be
converted. |
length
Integer. Specifies the desired
length of the binary string.
String. Returns the converted
binary string
Set the length parameter to 0 to have the
function return the significant digits of the conversion (no leading zeros).
d2b(3452,0)
The above example will return a string value of "110101111100".
