d2h PowerHome formula function
Converts decimal number into hexadecimal
string
d2h( number, length
| number |
Unsigned Long. The decimal number to be
converted. |
length
Integer. Specifies the desired
length of the hexadecimal string.
String. Returns the converted
hexadecimal string
Set the length parameter to 0 to have the
function return the significant digits of the conversion (no leading zeros).
d2h(3452,0)
The above example will return a string value of "D7C".
