double PowerHome formula function
Converts a string to a double number.
double ( s )
s
A string whose value you want returned as a double value.
Double. Returns the value of the string as a double. If the string is not a valid number or if it contains an incompatible datatype, Double returns 0.
To distinguish between a string whose value is the number 0 and a string whose value is not a number, use the IsNumber function before calling the Double function.
