fill PowerHome formula function
Builds
a string of the specified length by repeating the specified Unicode characters until the result string is long enough.
fill ( chars, n )
chars
A string whose value will be repeated to fill the return string
n
A long whose value is the length of the string you want returned
String. Returns a string n characters long
filled with repetitions of the characters in the argument chars. If the argument
chars has more than n characters, the first n characters of chars are used to
fill the return string. If the argument chars has fewer than n characters, the
characters in chars are repeated until the return string has n characters.
