h2s PowerHome formula function
Decodes a hex-encoded string to its non
hex-encoded form with option to save directly to
a file
h2s ( as_input, as_file, ai_type )
| Argument | Description |
| as_input | String. The hex-encoded data contained within
a string. Ex: "54455354" which is the ANSI hex-encoded value for "TEST" |
| as_file | String. The full path and filename that you want the decoded
hex to be saved to. If not saving to a file use an empty string "" |
| ai_type | Integer. The type of output to be returned by the function. See Usage below. |
String. Returns the
decoded data as a
string if the ai_type parameter is 0 or 1. For ai_types 2 thru 6, returns
"*SUCCESS" if successful and "*ERROR" if
an error occurs.
Use this function to convert hex-encoded
data back to its original format. If you use ai_type = 0, the function
expects the encoded hex string to be in ANSI format (1 byte = 2 hex digits = 1
character). If you use ai_type = 1, the hex encoded string should be in UTF8
format (2 bytes =
4 hex digits =
1 character). You should not use
ai_type 0 or 1 for binary encoded hex data. The
following ai_type values
are available:
- 1 - Return the decoded hexadecimal string from the
function. The hex string should contain UTF8 encoded
data.
- 2 - Save the decoded hexadecimal string in the file
specified in the second parameter. The file will be appended to and the
encoding will be what currently exists in the file.
- 3 - Save the decoded string in the specified file.
This operation will overwrite the file if it already exists and will save with
ANSI encoding.
- 4 - Save the decoded string in the specified
file. This operation will overwrite the file if it already exists and
will save with UTF8 encoding.
- 5 - Save the decoded string in the specified
will save with UTF16LE encoding.
- 6 - Save the decoded string in the specified
will save with UTF16BE encoding.
- 0 - or any other value will return the decoded hexadecimal string from the function. The hex string
should contain ANSI encoding.
• h2s("54455354","",0) - Returns the string "TEST"
• h2s("54455354","c:\powerhome\test.txt",2) - Appends the string "TEST" to the c:\powerhome\test.txt file
• h2s("5400650073007400","",1) This call will return the string "Test".
• h2s("5400650073007400","c:\output.txt",4) This call will create the file c:\output.txt with UTF8 encoding and write the string "Test" to it. The function will return "*SUCCESS" if succesful and will return "*ERROR" if it fails.
