left PowerHome formula function
Obtains a specified number of characters from the beginning (left side) of a string.
left ( string, n )
| Argument | Description |
| string |
String containing the characters you want to search. |
| n |
Integer. A number specifying the number of characters you want to return. |
String. Returns the leftmost n characters in string if it succeeds and the empty string ("") if an error occurs.
If n is greater than or equal to the length of the string, Left returns the entire string. It does not add spaces to make the return value's length equal to n.
The following examples demonstrate typical syntax/ usage for this function.
• left("[LOCAL1]",10) --> get the first 10 characters from the string.
• if( left( "[LOCAL1]", 12 ) = "HTTP/1.1 404", "ERROR", "Nextline")
