ph_base64decode1 PowerHome formula function (Deprecated)
Decodes a base64 string
returning
the output as a string of decimal ASCII codes.
ph_base64decode1 ( input )
input
Base64 string to decode.
String. Returns the decoded
base64 input as a concatenated list of ASCII values.
ph_base64decode1("VEVTVA== ") This call
will return the string "084069083084". The actual ASCII characters
(084
069 083 084) equate to
the string of
"TEST"
