ph_ccmapinfo PowerHome formula function
Generates HTML image map data for a Control Center tab.
ph_ccmapinfo ( id, image, mapname, nexturl, target, pagetype, imagetype, flags )
id
String. The ID of the Control Center tab to generate image map data.
String. The path and filename of the graphic file to be included in the image map HTML.
mapname
String. A string representing the name of the image map within the HTML.
nexturl
String. A string representing the next URL to be loaded as a result of clicking on the image map.
target
String. The target in which to send the nexturl data.
pagetype
Integer. The pagetype for the resulting CCMAP page for navigation type buttons.
imagetype
Integer. The imagetype for the resulting CCMAP page for navigation type buttons.
flags
Integer. The flags for the resulting CCMAP page for navigation type buttons.
String. Returns the HTML image map data.
You can combine this function with the ph_ccimage function to create a dynamic HTML image map file for a Control Center tab.
