ph_ccmodifyid PowerHome formula function
Modifies a Control Center tab by applying specifications, given as a list of instructions, that change the Control Center object's definition.
ph_ccmodifyid ( id, modstring )
id
The ID of the Control Center tab you are modifying.
modstring
A string whose value is the specifications for the modification.
Returns the empty string ("") if it succeeds and an error message if an error occurs. The error message takes the form "Line n Column n incorrect syntax".
