ph_checktrigger PowerHome formula function
Forces the checking of a trigger. Useful for external applications interfacing with PowerHome via Windows messaging or Socket Server interface.
ph_checktrigger ( type, id, number, value, dim, command, data, formula, auxvalue )
type
The type of trigger to check.
id
The Trigger ID
number
The Trigger Number
value
The Trigger Value.
dim
A double representing the dim value.
command
An unsigned long representing the command.
data
A long representing the data.
formula
A string representing the formula.
auxvalue
A string representing the auxillary value.
Integer. Returns a 1 if no matching triggers are found. Returns a 0 otherwise.
This function can be used to force a an internal PowerHome trigger check.
