ph_clearexequeue PowerHome formula function
Clears PowerHome COMM and Execution queues.
ph_clearexequeue ( )
Integer. Returns a 0.
When executed, this function will clear the PowerHome execution queue and the COMM queue. It does not affect Waiting macros however.
In order for this function to clear waiting execution queue items BEFORE this function is executed, you must execute this function in the boolean field of a trigger.
• ph_clearexequeue()   {No arguments needed}
