ph_combufferptr PowerHome formula function
Returns the number of characters read in the specified COM control's incoming buffer. As characters are read from the incoming buffer, this value is incremented to show how many characters have been read. The buffercount and bufferptr are automatically reset to 0 when the bufferptr = buffercount.
ph_combufferptr ( comnum )
comnum
The number of the COM control you are referencing. Valid values are 1 thru 5.
Long. Returns the number of characters read in the COM control's incoming buffer. Returns - 1 if a comnum < 1 or > 5 is specified. Returns - 2 if the specified COM control is not valid.
