ph_concatglobal PowerHome formula function
Concatenates a string value to an existing global variable.
ph_concatglobal ( id, string )
id
A string representing the ID of the global variable.
string
The string to concatenate to the global variable.
String. Returns the new value of the global variable. Returns the empty string if an error occurs. If the global variable currently contains a numeric value, it will be treated as a string and have the new string concatenated to it.
