ph_createdirectory PowerHome formula function
Creates the specified directory.
ph_createdirectory ( filespec )
filespec |
String representing the directory path/name you wish to have created. This function will only create a single directory at a time. |
Integer. Returns a 0 if successful and 1 if an error occurs.
• ph_createdirectory("C:/SprinklerTimes")
