ph_createglobal PowerHome formula function
Creates and initializes a PowerHome global variable on the fly.
ph_createglobal ( id, value )
id |
String. The ID of the global variable to create. |
value |
String representing the initial value to assign to the global variable |
Integer. Returns 0 if successful. Returns a 1 if an error occurred such as the ID already existing.
• ph_createglobal("MOTIONCOUNT","0")
• ph_createglobal("MOTIONCOUNT", "[LOCAL1]")
• ph_createglobal("CAMERA_NAME","DrvCam")
