ph_dbwhereused PowerHome formula function
Dynamically creates a SQL string that will
search for the specified search string with the option to execute the SQL and
return all instances where the search
string is found
ph_dbwhereused ( as_search, ai_flags )
| Argument | Description |
| as_search | String. The search parameter to looked for
within the PowerHome database. Use the "%" character as a wildcard. |
| ai_flags | Integer. Flags controlling how the data is to be returned. |
String. Returns either a string
containing the dynamically generated SQL statements to search the database or
the actual results of executing the SQL statements against
Use this function to build SQL
statements that allow you to search the PowerHome database for a specific search
term and optionally perform the search and return the results. This function
will use the PowerHome database dictionary to build appropriate SQL statements
to search tables and character based columns for the search term. This
function will not search numeric column datatypes or date datatypes and will
only include character based columns in the generated SQL. This function is
used by the menu item "Database Where Used" option under the
"Reports" menu.
Note: Most of the time your search term will be surrounded by the "%" wildcard character to make partial matches. Without wildcards, the search string must EXACTLY match the entire contents of the searched column
Valid values for the ai_flags parameter (multiple desired values are added together to get a final value) are:
1 - SQL will include text descriptions of returned
values
2 - Exclude generating SQL for tables in the DBWUEXCLUDE table
4 - Include searching tables that don't have a primary
key
8 - Return the result of actually executing the search
SQL rather than the SQL itself
ph_dbwhereused("%email%",15) - Generates SQL searching for the word "email" within PowerHome tables that have a primary key and are not excluded in the DBWUEXCLUDE table. The data
returned will be the results of actually running the generated SQL and will
include text identifiers for the returned column
values
