ph_debuginfo PowerHome formula function
Returns debug information associated with the active PowerHome controllers and internal PowerHome variables. This is the same information that is returned by the menu option "Debug Info" under the "File" menu
ph_debuginfo ( )
Argument Description
String. Returns the generated debug information for internal PowerHome variables and controls as well as internal information for each of the active controllers defined within PowerHome.
Use this function to peek at what is going on within PowerHome in order to debug potential issues or problems
• ph_debuginfo()
