ph_decrypt PowerHome formula function
This function will decrypt strings that were
previously encrypted using the ph_encrypt
function
ph_decrypt ( data, key
| data |
String. The encrypted string you wish to decrypt. |
key
String. The key to use for
decryption. This key must match the key that was used to encrypt the
data originally.
String. Returns the decrypted string
in standard
ASCII format.
The ph_encrypt and ph_decrypt functions use
the Microsoft Cryptograghy library.
ph_decrypt("C2DB941D6A1754A02778D80C9C91","abc123") The
output of this function will be the originally encrypted string: "This is a
test". The "abc123" is the key/password that used to orignally encrypt the
string.
