ph_deletefile PowerHome formula function
Deletes the specified file.
ph_deletefile ( targetfilespec )
targetfilespec |
String representing the full path and filename of the file to delete. |
Integer. Returns a 0 if the file was successfully deleted. Returns 1 if an error occurred.
• ph_deletefile("C:/powerhome/Bak/powerhome.db")
