ph_deleteglobal PowerHome formula function
Deletes a PowerHome global variable on the fly.
ph_deleteglobal ( id )
id |
String. The ID of the global variable to delete. |
Integer. Returns 0 if successful. Returns a 1 if an error occurred such as the ID not existing.
• ph_deleteglobal("MOTIONCOUNT")
