ph_deletetimedevent PowerHome formula function
Delete a timed event.
ph_deletetimedevent ( )
ph_deletetimedevent ( as_id )
as_id
String (Optional). A valid Timed event ID. If this parameter is omitted, then
the system variable TIMEDEVENT will be used for ID
Integer. Returns 0 if successful. Returns 1 if an error occurs
Use this function to programmatically delete timed events from the
PowerHome system.
ph_deletetimedevent("SUNRISE")
