ph_devicecontrol PowerHome formula function
Allows the user to pass a standard Device Control String and have it performed.
ph_devicecontrol ( as_control )
as_control
String.
A valid Device Control String.
Integer. Returns the result of the Device Control Evaluation.
See the Device Control Strings produced by
the Device Control String builder for examples on valid strings. You also have
the option of performing multiple device control action but separating the Device Control strings with a '|'
ph_devicecontrol("INSTEON+KITCHENFANLIGHT+ON")
The next example demontrates multiple Device Control strings (3)
to be executed sequentially.
ph_devicecontrol("INSTEON+KITCHENFANLIGHT+ON|INSTEON+FRONTCOACH+ON|X10+HTPC+OFF")
