ph_disabletrigger PowerHome formula function
Disables an enabled PowerHome trigger.
ph_disabletrigger ( )
ph_disabletrigger ( as_id )
as_id |
String (Optional). The ID of the trigger you wish to
disable. If this parameter is omitted, the system variable TRIGGER will be used for ID |
Integer. Returns a 0
• ph_disabletrigger("LIVROOM_OFF")
