ph_enabletrigger PowerHome formula function
Enables a disabled PowerHome trigger.
ph_enabletrigger ( )
ph_enabletrigger ( as_id )
as_id |
String (Optional). The ID of the trigger you wish to
enable. If this parameter is omitted, the system variable TRIGGER will be used for ID |
Integer. Returns a 0
• ph_enabletrigger("LIVROOM_OFF")
• ph_enabletrigger("[TEMP2]") --> where TEMP2 contains a valid trigger ID
