ph_encrypt PowerHome formula function
This function will encrypt strings using a
user specified
key.
ph_encrypt ( data, key
| data |
String. The data you would like to encrypt. |
key
String. The key to use for
encrypting the data. This can be a pass phrase or similar. In
order to decrypt, you must use the same key that was used
for encryption.
String. Returns the encrypted string in
hex format.
The ph_encrypt and ph_decrypt functions use
the Microsoft Cryptograghy library.
ph_encrypt("This is a test","abc123") The
output of this function will be the encrypted string:
"C2DB941D6A1754A02778D80C9C91". The "abc123" is the key/password that used
to encrypt the
string.
