ph_exporteventlog PowerHome formula function
Allows you to export the PowerHome eventlog into a file format of your choice with the option to trim the log.
ph_exporteventlog ( start, end, type, filename, colheading, trim )
start
A datetime representing the first row to export.
end
A datetime representing the last row to export.
type
An integer representing the type of file to export to. See Usage for details.
filename
A string representing the directory and filename to export to.
colheading
An integer representing whether column headings should be exported or not. A value of 0 will save without column headings. Any other value will save with column headings.
trim
An integer representing whether to trim the exported records or not. A value of 0 will cause the log NOT to be trimmed. Any other value will have the exported records trimmed from the weblog and eventlog tables.
Long. Returns the number of rows actually exported. Returns a negative number if an error occurs. - 1 is returned if an error occurs during the retrieval. - 2 is returned if an error occurs while exporting the rows. - 3 is returned if an error occurs while trimming the weblog table. - 4 is returned if an error occurs while trimming the eventlog table.
The following export types are supported. 0 = Excel, 1 = Text, 2 = Comma separated values, 3 = SYLK, 4 = WKS (Lotus), 5 = WK1 (Lotus), 6 = DIF, 7 = Dbase2, 8 = Dbase3, 9 = SQL Insert statements, 10 = Clipboard, 11 = PSR Report, 12 = Windows Metafile, 13 = HTML Table, 14 = Excel 5, 15 = XML, 16 = XSLFO, 17 = PDF, 18 = Excel 8. Any other value will default to type 1 which is text.
