ph_extractval PowerHome formula function
Extracts a value from a string containing a
structured list of
name/value pairs
ph_extractval ( as_data, as_id, as_sep )
| Argument | Description |
| as_data | String. A string containing a list of
name/value pairs. See Usage below. |
| as_id | String. The ID within the list to extract the value |
| as_sep | String. The separator character(s) that
separate the ID and VALUE data |
String. Returns the VALUE associated
with the specified ID (as_id). Returns "*ERROR* - Unable to locate ID" if the ID
cant be located. Returns "*ERROR* - Unable to locate value" if the value
cant be returned.
Use this function to quickly search
and return values from a structured list contained within as_data. This
function expects 1 name/value pair per line with lines separated by carriage
return line feed characters (~r~n). The name/value pair is separated from each
other by one or more "separator" characters (as_sep). A sample
as_data string containing 5 name/value pairs with a "," as the separator character could
look like:
Temp,75.0
Humd,55.3
Forecast,Cloudy
Level,32
• ph_extractval(ph_readfile("c:\powerhome\data.txt"),"Forecast",",")
- Returns the string "Cloudy" if the list above is contained within a file
located at c:\powerhome\data.txt
