ph_fileexists PowerHome formula function
Checks whether the specified file exists or not.
ph_fileexists ( filespec )
filespec |
String representing the full path and filename of the file to check. |
Integer. Returns a 1 if the file exists. Returns 0 if the file is not found.
• ph_fileexists("C:/powerhome/myalerts.txt")
