ph_filelength PowerHome formula function
Returns the length of the specified file in bytes.
ph_filelength ( sourcefilespec )
| sourcefilespec |
String representing the full path and filename of the source file. |
Long. Returns the length of the specified file in bytes.
• ph_filelength("C:/powerhome/MotionDetection.txt")
