ph_finddata PowerHome formula function
Finds data in a data retrieval area that was selected from an SQL Select.
ph_finddata ( n, s, start, end )
n
The number of the data retrieval area (1 – 5)
s
A string whose value is a boolean expression that you want to use as the search criterion. The expression includes column names
start
A long identifying the row location at which to begin the search.
end
A long identifying the row location at which to end the search. To search backward, make end less than start
Long. Returns the number of the first row that meets the search criteria within the search range. Returns 0 if no rows are found and a negative number if an error occurs. If any argument's value is NULL, Find returns NULL.
