ph_fixhtmlquotes PowerHome formula function
Replaces single and double quotes embedded within a string with the HTML escape code equivalent.
ph_fixhtmlquotes ( s )
s
The string in which you wish to replace single and double quotes.
String. Returns the string with single and double quotes replaced with their HTML escape code equivalent. Single quotes will be replace with ' and double quotes will be replaced with "
