ph_flattenjson PowerHome formula function
Takes a string containing valid JSON data
and flattens it into a list of name/value pairs with the
specified separator
ph_flattenjson ( as_json, as_sep, ai_flags, ai_type )
| Argument | Description |
| as_json | String. A string containing valid JSON |
| as_sep | String. The separator character(s) you would
like to use for the name/value pairs |
| ai_flags | Integer. Flags controlling how the JSON is
flattened. See Usage below |
| ai_type | Integer. The particular method to use for the
flattening of JSON data. Valid values are 0, 1, and 2 |
String. Returns the JSON data
flattened into a name/value pair string with 1 name/value pair per line. If
an error occurs, returns a string starting with "*ERROR*" followed by a
description
of the error
Use this function to "flatten" JSON
data into name/value pairs such that other functions within PowerHome (such
as ph_extractval or the regular expression functions) can be used to extract
specific data.
The ai_type parameter controls the specific method used to flatten the JSON data with each method returning potentially different results. Type 0 uses a character by character parsing routine to flatten the JSON data. Type 1 uses a C# dictionary and JTokens to flatten the JSON. Type 2 uses a C# dictionary and JObjects to deserialize and flatten the JSON.
Each of the 3 types (0, 1, 2) allow different ai_flag parameters to be specified to control the operation. Not all flags are supported in all types. The supported flag values and which types they apply to are listed below. The desired flag values are added together to achieve the final result to be passed in the ai_flags parameter:
1 - Encloses the flattened JSON NAME in double quotes. Supported by types 0, 1, and 2.
2 - Encloses the flattened JSON VALUE in double quotes. Supported by types 0, 1, and 2.
4 - Strip commas contained within a JSON NAME. Supported by type 0.
8 - Strip commas contained within a JSON VALUE. Supported by type 0.
16 - Strip double quotes contained with a JSON VALUE.
Assume the file named c:\powerhome\json.txt contains the following JSON data: {"people":[{"name":"John","age":31,"city":"New York","phones":["4075551212","3215551212","8885551212"]}]}
• ph_flattenjson(ph_readfile("c:\powerhome\json.txt"),":",0,0) will return:
people.name:John
people.age:31
people.city:New York
people.phones:[4075551212,3215551212,8885551212]
• ph_flattenjson(ph_readfile("c:\powerhome\json.txt"),":",0,1) will return:
people.0.name:John
people.0.age:31
people.0.city:New York
people.0.phones.0:4075551212
people.0.phones.1:3215551212
people.0.phones.2:8885551212
• ph_flattenjson(ph_readfile("c:\powerhome\json.txt"),":",0,2) will return:
people[0].name:John
people[0].age:31
people[0].city:New York
people[0].phones[0]:4075551212
people[0].phones[1]:3215551212
people[0].phones[2]:8885551212
