ph_flattenxml PowerHome formula function
This function takes a string in XML format
and flattens it to a carriage return linefeed separated list of
name/value pairs
ph_flattenxml ( as_xml, as_sep, ai_flags, ai_type )
| Argument | Description |
| as_xml | String. The XML data to be flattened |
| as_sep | String. The separator character(s) to be used
to separate the name/value pairs in the output |
| ai_flags | Integer. Flags controlling how the flattened
data is returned. See Usage below |
| ai_type | Integer. The type of flattening to be
performed. Valid values are 0 and 1 |
String. The flattened XML data is
returned as a carriage return linefeed separated list of name/value pairs if
successful. If an error occurs, the string "*ERROR*" followed by the error
details
will be returned.
Use this function
to "flatten" XML data into name/value pairs to make it easier for
other PowerHome functions to extract specific data.
The ai_type parameter controls the specific method used to flatten the XML data with each the two methods returning potentially different results. Both methods (ai_type = 0 and ai_type = 1) use C# XDocuments to parse the XML.
Both type 0 and type 1 allow different ai_flag parameters to be specified to control the operation. Not all flags are supported in both types. The supported flag values and which types they apply to are listed below. The desired flag values are added together to achieve the final result to be passed in the ai_flags parameter:
1 - Encloses the flattened XML NAME in double quotes. Supported by both types 0 and 1.
2 - Encloses the flattened XML VALUE in double quotes. Supported by both types 0 and 1.
4 - Preceed XML array numbers with a period character instead of an open bracket. Supported only by type 1.
8 - Append XML array numbers with a period character instead of a close bracket. Supported only by type 1.
Assume that the file named c:\powerhome\xmldata.txt contains the following XML data: <XMLROOT><people><name>John</name><age>31</age><city>New York</city><phones>4075551212</phones><phones>3215551212</phones><phones>8885551212</phones></people></XMLROOT>
• ph_flattenxml(ph_readfile("c:\powerhome\xmldata.txt"),0,0) will return:
XMLROOT.people.name:John
XMLROOT.people.age:31
XMLROOT.people.city:New York
XMLROOT.people.phones:4075551212
XMLROOT.people.phones:3215551212
XMLROOT.people.phones:8885551212
• ph_flattenxml(ph_readfile("c:\powerhome\xmldata.txt"),0,1) will return:
XMLROOT.people.phones[0]:4075551212
XMLROOT.people.phones[1]:3215551212
XMLROOT.people.phones[2]:8885551212
