ph_formulabtnparm PowerHome formula function
Executes a PowerHome saved formula
(PowerHome Explorer->PowerHome->Formulas) with optional
parameters.
ph_formulabtnparm ( vartype, id, local1,
local2, local3, local 4, local5
| vartype |
Integer. Determines whether the current set of variables
will be updated during the formula evaluation or current variable values
will be preserved. Use 0 to update the current set of variables. Use
any other number to preserve the current values. |
| id |
String. The ID of the Formula that you'd like to have
evaluated. |
| local1 |
Any. This value will become the new LOCAL1 value. |
| local2 |
Any. This value will become the new LOCAL2 value. |
| local3 |
Any. This value will become the new LOCAL3 value. |
| local4 |
Any. This value will become the new LOCAL4 value. |
local5
LOCAL5 value.
String. Returns the result of the
formula evaluation.
You can use this function similar to
calling a macro
with parameters.
ph_formulabtnparm(1,"SENDEMAIL","youraddress@email.com","Subject","Message
body",0,0)
The above example will execute the
SENDEMAIL formula that was previously created in the PowerHome Explorer.
It will set the LOCAL1 thru LOCAL5 variables with LOCAL1 being the address to
send email to, LOCAL2 being the subject of the email, and LOCAL3 being the body
of the email. LOCAL4 and LOCAL5 are not needed by the formula so their
values are default set to 0. The first parameter (vartype) of 1 will cause
the current variable set to be preserved with no changes occuring to any variables as a result of running the function.
