ph_funcdef PowerHome formula function
This function will return the function
definition of any of the PowerHome specific functions
(ph_???)
ph_funcdef ( function
function
String. The name of the function
you'd like to return the
definition of.
String. Returns the function
definition of the specified function showing argument types
and names.
Use this function to view the definition
for any PowerHome specific function that may not be documented in the help
file. Use the ph_funclist function to return a list of all PowerHome
specific functions.
ph_funcdef("ph_insteonwithret") The result
of this function will be: integer ph_insteonwithret (string as_id, integer
ai_cmd1, integer
ai_cmd2)
