ph_funclist PowerHome formula function
Retrieves a list of all PowerHome specific function names.
ph_funclist ( )
Argument Description
String.  Returns the list of function names separated by carriage return / linefeed characters.
Use this function to retrieve a list of function names of PowerHome internal functions.  This is useful in case an update does not have the function documented yet.  Once you have a name, you can use the ph_funcdev function to retrieve its definition.
ph_funclist()
This example will return all of the function names.  The first few lines of a typical call is displayed below:
d2h
f_phfnver
h2d
h2s
ph_addtoglobal
ph_addtovar
