ph_getanalog PowerHome formula function
Retrieves the value of an analog input / output defined in the Analog I/O screen.
ph_getanalog ( id )
id
The ID of the analogl I/O as defined within the Analog I/O screen.
String. Returns the CALCULATED value of the analog I/O if successful. Returns "- 100" if the ID cannot be found. When this function is executed, the controller, unit, and point is looked up within the Analog I/O table and these values are then passed to the controller. If these values are entered improperly in the Analog I/O screen, then the following errors may be returned: " - 1" is returned if the controller is not available, "- 2" is returned if an error ocurred while retrieving the analog value, "- 3" is returned if the controller does not support analog I/O, "- 4" is returned if the unit is out of range, "- 5" is returned if the point is out of range.
This function is similar to the ph_getotheranalog function except that the point MUST be defined within the Analog I/O screen. Note that this function returns the CALCULATED value whereas the ph_getotheranalog function returns the RAW value.
