ph_getanalogcalcstat PowerHome formula function
Retrieves the current calculated value of a Analog device in the Device Status Screen. This function DOES NOT cause the controller to retrieve the values and only returns what is currently stored within PowerHome.
ph_getanalogcalcstat ( )
ph_getanalogcalcstat ( as_id )
as_id
String (Optional). The ID of the analog device to
retrieve the calculated value for. If this parameter is omitted, the system variable ANALOG will be used for the ID
String. Returns the currently stored calculated value for the specified analog device.
This function does not cause the controller to query the value. Use ph_getanalog to have the controller query the current raw value and calculate a new calculated value.
• ph_getanalogcalcstat("TEMPERATURE")
- Returns the calculated value for the TEMPERATURE Analog I/O device. This value
will be the same as that displayed in the Device Status
screen
