ph_getanalogstat PowerHome formula function
Retrieves the current raw value of an Analog device in the Device Status Screen. This function DOES NOT cause the controller to retrieve the values and only returns what is currently stored within PowerHome.
ph_getanalogstat ( )
ph_getanalogstat ( as_id )
as_id
String (Optional). The ID of the analog device to
retrieve the raw value for. If this parameter is omitted, the system variable ANALOG will be used for the ID
Long. Returns the currently stored raw value for the specified analog device.
This function does not cause the controller to query the value. Use ph_getotheranalog to have the controller query the current actual value.
• ph_getanalogstat("TEMPERATURE") -
Returns the raw value for the TEMPERATURE Analog I/O
device.
