ph_getccobjbcolor PowerHome formula function
Retrieves the background color for the specified Control Center object.
ph_getccobjbcolor ( )
ph_getccobjbcolor ( as_tab, as_id )
as_tab
String (Optional). The ID of the Control Center tab
containing the object. If this parameter is omitted, the system variable CCTAB will be used
as_id
String (Optional). The ID of the object on the specified
tab. If this parameter is omitted, the system variable CCOBJ will be used
Long. Returns the color value of the specified objects background. This value is equivalent to the value returned from the rgb() function. Returns - 1 if the object is not found.
Use this function to retrieve the
background color for a Control Center object on a CC tab. A typical use of this
function would be to retrieve the current background color of a Control Center object
that was triggered and initiated an action such as a formula or macro. In that
use case scenario, you can call the function without parameters and
the ID's for both the tab and object will be automatically supplied by the system variables. If you wish to get the background color for a CC object other than one that initiated an action, you must specify both the tab and object ID's
• ph_getccobjbcolor( ) - If called
from within a formula that was triggered by the action of a Control Center
object, returns the background color for that CC
object
• ph_getccobjbcolor("TV","POWER") - Returns the
background color for the POWER object on the TV Control Center
tab
