ph_getccobjborder PowerHome formula function
Retrieves the border value for the specified Control Center object.
ph_getccobjborder ( )
ph_getccobjborder ( as_tab, as_id )
as_tab
String (Optional). The ID of the Control Center tab containing the object. If this parameter is omitted, the system variable CCTAB will be used
as_id
String (Optional). The ID of the Control Center object on the specified tab. If this parameter is omitted, the system variable CCOBJ will be used
Integer. Returns the border value of the specified object. 0 is returned for no border, 2 is returned for a box border, 5 is returned for a lower border, 6 is returned for a raised border, and 10 is returned for a button border. Returns -1 if the object is not found.
Use this function to retrieve the
border value for a Control Center object on a CC tab. A
typical use of this function would be to retrieve the current border
value of a Control Center object that was triggered and initiated an
action such as a formula or macro. In that use case scenario, you can call the
function without parameters and
the ID's for both the tab and object will be automatically supplied by the system variables. If you wish to get the border value for a CC object other than one that initiated an action, you must specify both the tab and object ID's
• ph_getccobjborder( ) - If called
from within a formula that was triggered by the action of a Control Center
object, returns the border value for that CC
object
• ph_getccobjborder("TV","POWER") - Returns the border
value for the POWER object on the TV Control Center
tab
