ph_getccobjgraphic PowerHome formula function
Retrieves the current graphic file in use by a Control Center graphic object.
ph_getccobjgraphic ( ai_type )
ph_getccobjgraphic ( as_tab, as_id, ai_type )
as_tab
String (Optional). The tab ID containing the graphic
object. If this parameter is omitted, the system variable CCTAB will be used
as_id
String (Optional). The ID of the Control Center graphic
object. If this parameter is omitted, the system variable CCOBJ will be used
ai_type
Integer. The type of graphic file to be returned. Use 0 for the "up" graphic file, 1 for the "down" graphic file.
String. Returns the full path and filename of the specified graphic object. Returns "- 1" if the tab/object cannot be found.
Use this function to retrieve
the graphic file for a Control Center
graphic object on a CC
tab. A typical use of this function would be to retrieve the current graphic file of a Control Center
graphic object that was triggered and initiated an action such as
a formula or macro. In that use case scenario, you can call the function
without the as_tab and as_id parameters and the ID's for both the tab
and object will be automatically supplied by the system variables. If you wish to get the graphic file for a CC graphic object other than one that initiated an action, you must use the syntax that includes the parameters for both the tab and object ID's
• ph_getccobjgraphic("FAMILYRM","FAMILYRMLIGHT",0) -
Retrieves the "up" graphic file for the FAMILYRMLIGHT graphic CC
object on the FAMILYRM
tab
