ph_getccobjheight PowerHome formula function
Retrieves the height for the specified Control Center object.
ph_getccobjheight ( )
ph_getccobjheight ( as_tab, as_id )
as_tab
String (Optional). The ID of the Control Center tab
containing the object. If this parameter is omitted, the system variable CCTAB will be used
as_id
String (Optional). The ID of the Control Center object on
the specified tab. If this parameter is omitted, the system variable CCOBJ will be used
Long. Returns the height of the specified object. Returns -1 if the tab/object is not found.
Use this function to retrieve
the height for a Control Center object on a CC tab. A typical use of this
function would be to retrieve the current height of a Control Center
object that was triggered and initiated an action such as a formula or macro. In
that use case scenario, you can call the function without parameters
and the ID's for both the tab and object will be automatically supplied by the system variables. If you wish to get the height for a CC object other than one that initiated an action, you must specify both the tab and object ID's
• ph_getccobjheight("TV","POWER") -
Retrieves the height for the POWER object on the TV
tab
