ph_getccobjtext PowerHome formula function
Retrieves the text for the specified Control Center object.
ph_getccobjtext ( )
ph_getccobjtext ( as_tab, as_id )
as_tab
String (Optional). The ID of the Control Center tab
containing the object. If this parameter is omitted, the system variable CCTAB will be used
as_id
String (Optional). The ID of the Control Center graphic
object. If this parameter is omitted, the system variable CCOBJ will be used
String. Returns the text of the specified object. Returns "- 1" if the tab/object is not found.
Use this function to retrieve
the text for a Control Center object on a CC tab. A typical use of this
function would be to retrieve the current text of a Control Center
object that was triggered and initiated an action such as a formula or macro. In
that use case scenario, you can call the function without
parameters and the ID's for both the tab and object will be automatically supplied by the system variables. If you wish to get the text for a CC object other than one that initiated an action, you must specify both the tab and object ID's
• ph_getccobjtext("TV","MODE") -
Returns the text associated with the CC object MODE on tab
TV
